Where is the turn signal relay located?
JRY VA
  • 2019 GMC ACADIA
  • 36,000 MILES
I'm trying to find the turn signal relay. Can anyone help?
Friday, July 28th, 2023 AT 6:28 PM
  • 108,517 POSTS
The turn signals on this vehicle don't have a relay or a flasher. Ground is applied at all times to the turn signal/multifunction switch. The turn signal lamps may only be activated with the ignition switch in the On or Start positions. When the turn signal/multifunction switch is placed in either the Turn Right or Turn Left position, ground is applied to the body control module (BCM) through either the right turn or left turn signal switch signal circuit. The BCM responds to the turn signal switch input by applying a pulsating voltage to the front and rear turn signal lamps through their respective control circuits.
So, what is actually happening?
Friday, July 28th, 2023 AT 10:02 PM
JRY VA
It's because I installed some LED turn signals they hyper flash is there any other way I can fix that?
Friday, July 28th, 2023 AT 10:10 PM
  • 108,517 POSTS
The only thing you can do is place a resistor at the lights. The LEDs require little power to turn on, so the system thinks you have a burnt-out bulb.
Because this is controlled by the BCM, you can't get a flasher designed for this. Instead, you will need to get a load resister for each bulb. To do this for an indicator (turn signal), it has to be wired into each LED light bulb in parallel. In other words, the load resistor goes across the light bulb connections, between the supply and ground and draws power away from the bulb. This causes the circuit to believe there is a normal bulb being used and nothing has failed.
Check online for load resistors for automotive LED bulb installation.
Take a look for this information online and let me know what you find or if you have other questions.
joe
Friday, July 28th, 2023 AT 10:31 PM
JRY VA
Okay, I'll sure do that. Thanks for the help.
Friday, July 28th, 2023 AT 10:57 PM
  • 108,517 POSTS
You are very welcome. If you have a chance, could you let me know how things turn out for you? I'm interested in knowing.
Also, if you run into trouble, let me know and I'll try to help from here.
Saturday, July 29th, 2023 AT 8:15 PM
