Engine noise lose of power
TINA LADYBEAR MCCARTY
  • 1997 HONDA ACCORD
  • 2.4L
  • 4 CYL
  • FWD
  • 180,900 MILES
The engine has always had a growl but resently we had to replace harmonic balancer, about 900 miles ago since then the noise is getting louder and it's starting to lose power. Could it be as simple as Ajusting the belts? Note about the noise I'm pretty sure the noise is a bent lifter? I'm no mechanic, But I do have a general idea about it. Just need a direction to go. Thanks in advance
Tuesday, October 4th, 2016 AT 12:41 AM
HMAC300
  • 48,600 POSTS
For noises like this have a local mechanic check it out normally there is no charge, if it's a bent lifter what you call may actually be a cam lobe wearing out.
Tuesday, October 4th, 2016 AT 6:29 AM
Ok thank you
Tuesday, October 4th, 2016 AT 7:33 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,530 POSTS
Please let us know what you find so it will help others.
Best, Ken
Friday, October 7th, 2016 AT 12:20 PM
