Engine shuts off when transmission is shifted into gear?
DPINSON
  • 1997 SUBARU LEGACY
  • 4 CYL
  • 4WD
  • 50,000 MILES
Replaced alternator and battery, ran fine first half of the day, now shutting off when you put it in gear.
Thursday, January 25th, 2024 AT 2:37 PM
  • 108,401 POSTS
Based on what you replaced and the symptoms, it sounds like the alternator may not be charging as it should. If you haven't already, I need you to check it.
Here is a link that explains how to check the alternator's output. All you will need is a basic volt or multimeter. Follow this link and let me know what you find:
Also, let me know if the alternator or the battery were replaced because both failed or was it one of the other.
Thursday, January 25th, 2024 AT 8:27 PM
