Engine coolant over temperature alert
JAMES POLI
  • 2014 FORD FUSION
  • 4 CYL
  • 85,000 MILES
I was driving down the highway and when I got off, the alert popped up saying, "engine coolant over temperature." I did not see any leaks and am pretty weary of the diagnosis I got from the mechanics saying that the water pump needs to be replaced along with the serpentine belt. Over $1,200.00 (that I do not have). I am looking for some suggestions on how to properly diagnose the problem and repair it myself.
Wednesday, May 30th, 2018 AT 8:35 PM
  • 31,937 POSTS
I would be looking at the thermostat and cooling fans first. Also, make sure that there is no debris building up around the radiator core as this can limit air flow. Is the temperature gauge running at the normal position? Also, is the coolant level correct in the surge tank? If low a cooling system pressure test will help locate any minor leaks.
Wednesday, May 30th, 2018 AT 10:13 PM
JAMES POLI
The coolant level is correct and the gauge is showing all the way up to the H.
Saturday, June 2nd, 2018 AT 1:17 PM
  • 31,937 POSTS
I would start with replacing the thermostat it sounds as if it may be stuck closed.
Saturday, June 2nd, 2018 AT 5:04 PM
CHAPA9182
  • 5 POSTS
I also have a 2014 Fusion, it started making a noise like it was the crankshaft pulley. Then my car got overheated after a few days of making noise and went into limp mode. Had to have it towed home. Started checking the car and found it was the water pump that was making the noise and went out. You could move the pulley up and down. It never leaked any coolant. Replaced pump and timing belt. Had to clear codes to get it out of limp mode. Hope this helps.
Thursday, January 9th, 2020 AT 9:54 AM
CHAPA9182
  • 5 POSTS
By the way it has a 1.5L engine.
Thursday, January 9th, 2020 AT 9:57 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,476 POSTS
Please feel free to use 2CarPros anytime!
Saturday, January 11th, 2020 AT 3:11 PM
THESKATE72
I also have a 2014 Ford Fusion 1.5 and it is having similar problems I replaced both radiators, the coolant sensor at the drain plug, the thermostat, had a pressure tested at Ford no concerns. Drove it for a month or two and it overheated going down the freeway around 80 miles an hour. I had it towed home and then to Meineke shop the next day. At Meineke they found no thing wrong with my car Reset the “engine coolant over temperature “ code. It’s uncomfortable with the diagnosis so I took it to a highly rated shop here in Phoenix they kept it half a day ran nearly 1/4or more gas out of my car and found nothing with it either. Car ran good for about a week in the hot Arizona sun until I got on the freeway again and around 80 miles an hour over heated again. Only thing I have left to replace would be the water pump but nobody’s found anything wrong with that. Also does anybody know how to reset the code on my car engine coolant over temperature code?
Sunday, September 13th, 2020 AT 4:35 PM
CHAPA9182
  • 5 POSTS
I borrowed the code reader from AutoZone to clear the code. You have to leave about $200.00 until you bring it back.
Monday, September 14th, 2020 AT 9:57 AM
4DRTOM
  • 467 POSTS
Yes, if you disconnect both battery terminals and short them together for 30 seconds it will clear all the codes in the car.
Here is an article to resetting the check engine light.
Review it and let me know how you do.
https://www.2carpros.com/articles/check-engine-light-clear-codes
Thanks, Tom
Monday, September 14th, 2020 AT 9:59 PM
