Engine back L fuse
JAMES STEVEN TODD III
  • 1991 ISUZU TRUCK
  • 3.1L
  • V6
  • 4WD
  • MANUAL
  • 227,000 MILES
Every time I turn the key, the engine back L fuse blows. I checked the alternator and all other fuses and I do not know what else to look for in the wiring. Does anyone have any idea of how to fix this?
Monday, May 21st, 2018 AT 2:35 PM
AL514
  • 4,127 POSTS
Hello, I think you are referring to the engine back up L fuse, so you have a short to ground some where. Is there a number for the fuse on the fuse box cover?
Tuesday, May 22nd, 2018 AT 7:50 AM
AL514
  • 4,127 POSTS
Also, try unplugging the alternator and turn the key on with a new fuse in, if it blows with the key on then the alternator has a short to ground. Just a quick try to eliminate the alternator as the problem.
Tuesday, May 22nd, 2018 AT 7:55 AM
