HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mazda
Protege
Engine
Symptoms
Stall at Idle
Engine will not stay running
JUNEBUGG
MEMBER
2001 MAZDA PROTEGE
2.0L
4 CYL
2WD
AUTOMATIC
155,764 MILES
I replaced the battery and started. Now it starts will turn over but won’t continue to run.
Saturday, March 23rd, 2019 AT 10:56 AM
JOETECHPRO
MECHANIC
Hey JUNEBUGG,
So it will start and run for a while and then shut off?
I would begin by checking for fault codes.
Link to a how to guide below:
Let us know if you have any further questions.
Regards, Joe
SPONSORED LINKS
Saturday, March 23rd, 2019 AT 1:48 PM
Please
login
or
register
to post a reply.
Related Engine Stall At Idle Content
1999 Mazda Protege Engine Stall At Idle After Battery...
My Old Battery Was Made 2001 And Had White Deposit Over It. Some I Clean (with Baking Power Solution), Protect And Replace A New Battery...
Asked by
lsman
1999
MAZDA PROTEGE
GUIDE
Engine Stalls After Dead or New Battery
So you installed a new battery and now the engine stalls? You have done nothing wrong because believe it or not this is normal. The engine computer has a learning cycle...
Will Not Idle
Has Dtcs P0505 P0340 P0100 P0115 P0110 P0120 P1195. And No Charge Light On. Not Sure If It's The Alternator Or The Ecm. Car...
Asked by
Chris121963
1 ANSWER
1997
MAZDA PROTEGE
2002 Mazda Protege Idles Fine, But Stalls At Low Rpm
The Car Starts Up And Idles Just Fine. However, When I Let Up Off The Clutch, I Have To Give It Quite A Bit Of Gas To Prevent It From...
Asked by
Gearman
1 ANSWER
2002
MAZDA PROTEGE
1993 Mazda Protege Car Won't Idle Anymore
I Brought My Protege Out From 5 Years Of Mothballs. Ran Great. Emissions Wouldn't Pass, But Ran Great Otherwise. I Decided To Perform A...
Asked by
pokie
1993
MAZDA PROTEGE
Mazda 1995 Protege
My Car Got Wet Because It Had No Hood Now The Car Starts And Runs For About 4 Minutes Then It Slowly Starts To Die What Could Be Wrong With...
Asked by
ysalgado
1 ANSWER
1995
MAZDA PROTEGE
VIEW MORE
SPONSORED LINKS
Stalls at Idle
Spark Plug and Wire Replacement Ford Mustang
Oil Change & Filter Replacement Toyota
Online car repair manuals
