Emissions readiness
PMRHONDA
  • 2012 HONDA CIVIC
  • 2.4L
  • 4 CYL
  • FWD
  • MANUAL
  • 160,000 MILES
I am currently trying to pass CT emissions (only one monitor is allowed to be "not ready". I have three: catalytic converter, oxygen and fuel system. How do I ensure these monitors are set? What is the procedure? I was told to just drive (which by the way is not very helpful advice.) Thank you in advance!
Thursday, December 22nd, 2016 AT 7:58 AM
STEVE W.
  • 13,201 POSTS
Make sure you have 1/4 to 3/4 tank of gas.
Park it overnight.
Start and idle the engine with A/C off for fifteen minutes.
Shut off engine for ten minutes.
Start engine and idle for five minutes.
Next, drive at a steady throttle (fifty mph) for twelve minutes.
Repeat steps three and six.
Thursday, December 22nd, 2016 AT 8:54 AM
PMRHONDA
  • 6 POSTS
Steve, I will give this a shot and let you know. I only have until February 1, 2017 to retest.
Thursday, December 22nd, 2016 AT 3:48 PM
STEVE W.
  • 13,201 POSTS
Plenty of time. Even normal use would get the monitors set by then.
Thursday, December 22nd, 2016 AT 4:06 PM
PMRHONDA
  • 6 POSTS
Hopefully, I am not kidding when I say I have driven this thing over 1,000 miles so far and the readiness is still not completely set.
Friday, December 23rd, 2016 AT 4:52 AM
PMRHONDA
  • 6 POSTS
Do I repeat the idle for 15 mins and then drive for 12 mins or do I shut it off for 10 then drive 12?
Friday, December 23rd, 2016 AT 10:53 AM
PMRHONDA
  • 6 POSTS
In response to repeating those two steps you were talking about
Friday, December 23rd, 2016 AT 10:54 AM
STEVE W.
  • 13,201 POSTS
Sorry should say steps three through six. Which monitors are not setting? EVAP is usually a bear to get because the test is very specific. Others should run just about every start.
Friday, December 23rd, 2016 AT 1:31 PM
PMRHONDA
  • 6 POSTS
O2 sensor, fuel system, and cat
Sunday, December 25th, 2016 AT 3:54 PM
STEVE W.
  • 13,201 POSTS
OK, reading some of the info I have says those can take a while.
This is a LONG post on the issue -
http://www.driveaccord.net/forums/4-problems-solutions/7261-emissions-test-problems-not-ready.html
Read through it and you might find something that would help set them faster.
Sunday, December 25th, 2016 AT 6:38 PM
