2000 Dodge Van spark plug wires removal
HKEVDOG4783
  • 2000 DODGE VAN
  • V8
  • 54,000 MILES
Im trying to change my spark plugs but my wire boot s on so tight I cant get enough leveridge. To pull them out. Theres a metal sleeve around them plus tight area. First tune up in 54000 miles. Isthereatool?
Friday, August 14th, 2009 AT 4:40 PM
  • 108,530 POSTS
There isn't a special tool. All you can do is twist them and then try to see if they will come off. If you can get a pair of pliers in there and use the metal shield as a leverage point, you may be able to pry them off. Other than that, twist and pull.
Sunday, October 11th, 2009 AT 12:55 PM
