HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Neon
Engine
Knock Sensor
Location
SPONSORED LINKS
2005 Dodge Neon
TSCOTT4409
MEMBER
2005 DODGE NEON
4 CYL
FWD
AUTOMATIC
48,000 MILES
THE CAR IS MISFIRING AND PUTTING.
WE RECEVIED SEVERAL PROBABLE CAUSES:
1. KNOCK SENSOR DEFECTIVE
2. LOW FUEL PRESSSURE
3. CAM SENSOR DEFECTIVE.
WHERE ARE THE SENSORS LOCATED?
Monday, September 22nd, 2008 AT 2:35 PM
BMRFIXIT
MECHANIC
I would rather if you list the codes
easier to point you in the right direction
fuel sensor is on the tank
cam sensor rear top of engine
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Tuesday, September 23rd, 2008 AT 8:15 PM
Please
login
or
register
to post a reply.
Related Knock Sensor Location Content
Locations Of The Coolant Temperature Sensor & Knock...
2.0 Non-turbo Sohc Engine
Asked by
henterprises
1 IMAGE
2005
DODGE NEON
Maf Or Map Sensor?
My Girlfriend Has An 05 Dodge Neon. The Check Engine Light Came On Recently And Now Runs Rough. Once The Car Hits About 2000 Rpms It Seems...
Asked by
jeff1545
1 IMAGE
2005
DODGE NEON
2005 Dodge Neon Camshaft Posittion And Knock Sensors
Last Night While Drivng My Wifes Neon The Check Engine Light Came On And It Starting Knocking. I Parked The Car And Today I Pulled The Codes...
Asked by
equipmentfixer
2005
DODGE NEON
2005 Dodge Neon Broken Timing Belt
Engine Mechanical Problem 2005 Dodge Neon 4 Cyl 67700 Miles I Was On The Way Home From When My Timing Belt Went Out. I Took It To...
Asked by
ChrisB37
1 ANSWER
2005
DODGE NEON
2005 Dodge Neon Mil, Possible Bad Fuel Or Oxygen...
2005 Dodge Neon 68000 Miles I Drive A 2005 Doge Neon With 68000 Miles On It. Yesterday I Was Driving And Notice That I Needed Gas. I...
Asked by
jessyh2005
2005
DODGE NEON
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Mercedes-Benz C230
Is it Safe to Drive Check Engine Light?
What to Do When a Check Engine Light?
Online car repair manuals
