1998 Dodge Intrepid Will not start
HAH
  • 1998 DODGE INTREPID
Engine Mechanical problem
1998 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
I have a 3.2L that will not start. The auto shutdown relay keeps activating even if the key is not in the ignition. I have changed the crankshaft position sensor but the car still will not turn over.
Monday, December 29th, 2008 AT 4:42 PM
  • 108,550 POSTS
Have you replaced the auto shutdown relay? Will the engine crank?
Tuesday, December 30th, 2008 AT 4:41 PM
HAH
Yes, I did replace the AutoShutdown relay but still the car does not crank.
Wednesday, December 31st, 2008 AT 11:47 AM
  • 108,550 POSTS
Hi:
I need you to check for power to the starter. Have a helper turn the key to the start position and check the small wire at the starter. It should have 12 volts when the key is in the start position.
Wednesday, December 31st, 2008 AT 3:46 PM
