2003 Dodge Durango Grinding Noise
BRTMOY7
  • 2003 DODGE DURANGO
Brakes problem
2003 Dodge Durango Four Wheel Drive Automatic
There is a constant grinding noise coming from the front passenger tire. We checked the brake pads, rotors and replaced the caliper. It is still grinding, while braking as well as while driving what else could cause this?
Tuesday, July 20th, 2010 AT 8:15 PM
BLACKOP555
  • 10,371 POSTS
May not be brakes. Start checking for wheel bearing issues
Tuesday, July 20th, 2010 AT 11:58 PM
BRTMOY7
I have raised the vehicle and spun the tire as well as checked for any loosness. How else would I check the bearing to cause the grinding?
Wednesday, July 21st, 2010 AT 1:11 PM
BLACKOP555
  • 10,371 POSTS
Wiggle the tire and look for play in the wheel on the spindle. If found there its wheel bearing. If its on the knuckle ball joints may be bad.
Wednesday, July 21st, 2010 AT 2:20 PM
