Dash lights intermittently stop working
SANDRA POWELL
  • 1997 HONDA ACCORD
  • 4 CYL
  • 4WD
  • 260,000 MILES
Dash lights flicker but won't stay on. Even after replacing sensor. And my speedometer stopped working. My radio works and lights up fine. Occasionally
speedometer and dash lights kick on then go out again.
Friday, October 15th, 2021 AT 6:33 PM
  • 108,401 POSTS
I read through schematics for both the dash lights and the speedo. They both plug into the rear of the instrument panel. What I found is both are powered from different fuses, so I don't see that as a possible issue. Since both fail at the same time, I have a feeling the connection on the rear of the cluster is loose or corroded.
If that checks good, I need you to locate the black wire in the connector and check it for continuity to ground. The ground for this component has a large wire splice. The wire itself could be corroded or loose in that splice.
When you check both the connection and the ground, while the connector is still attached to the cluster, move the wiring around to see if the lights flicker.
Saturday, October 16th, 2021 AT 10:25 PM
