HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chrysler
Sebring
Engine
Crankshaft
Sensor
Replace/Remove
Crankshaft position sensor relearn procedure?
NIGEL331
MEMBER
2009 CHRYSLER SEBRING
2.4L
4 CYL
2WD
AUTOMATIC
201,311 MILES
How can I manually, without using a scanner, do the relearn procedure for a newly installed crankshaft position sensor?
Friday, February 2nd, 2024 AT 12:40 PM
MECHANIC
On this vehicle, there is no relearn when you replace the crankshaft position sensor. Are you having trouble getting it to start after the repair?
Let me know. Also, if it isn't starting, check if there is spark at the plugs. If the CKP is a problem, there won't be spark.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
SPONSORED LINKS
Friday, February 2nd, 2024 AT 9:48 PM
Please
login
or
register
to post a reply.
Related Crankshaft Sensor Replace/Remove Content
1999 Sebring Convertible 201,000 Miles
My Sebring Has A 2.5 Engine. Two Years Ago I Replaced The Vapor Canister, Valve Vent And Crank Position Sensor. Nine Months Ago I Replaced...
Asked by
Lorraine11
1 ANSWER
1999
CHRYSLER SEBRING
GUIDE
Crankshaft Sensor Symptoms
Most modern car engines use a crankshaft sensor to monitor the engines crankshaft rotation. This sensor sends feedback information to the cars computer which then adjusts...
1999 Chrysler Sebring Crank Shaft Sensor Failure...
My Crank Shaft Sensor Failed And After It Was Replaced (they Had To "drill It Out") My "check Engin" Light Came On And Will Not Go Away. Its...
Asked by
Rondo8154
1 ANSWER
1999
CHRYSLER SEBRING
1998 Chrysler Sebring
1998 Chrysler Sebring 6 Cyl Automatic I've Replaced The Crank Sensor And Distributor And My Car Still Does'nt Get Any Fire. It Turns...
Asked by
Bud1028
1998
CHRYSLER SEBRING
2002 Chrysler Sebring Crank Sensor
What Causes Crank Sensor To Turn Off And On While Key Is Turning?And I Just Replaced The Crank Sensor.
Asked by
chevy3
1 ANSWER
2002
CHRYSLER SEBRING
Where Is The Crankshaft Position Sensor Located On A...
Where Is The Crankshaft Position Sensor Located On A 2004 2.4l Dohc Chrysler Sebring?
Asked by
RJG777
1 ANSWER
1 IMAGE
2004
CHRYSLER SEBRING
VIEW MORE
SPONSORED LINKS
Not Running - Advanced
How to fix an engine that wont start
Online car repair manuals
