Cranks and fires but will not start
ANDREW LANE
  • 1999 CHEVROLET TAHOE
  • 5.7L
  • V8
  • 4WD
  • 200,000 MILES
My SUV will not start. It has good spark and is getting plenty of gas but still will not start. I can here the engine fire as it cranks but it will not keep going and sometimes sputters a little bit after I stop turning the key. Also, it will not completely connect to code reader. Will not scan catalytic converter, EVAP, o2. Says there are emissions related engine DTCS but will not list. Any ideas?
Monday, January 15th, 2018 AT 2:00 PM
CATAFINA
  • 98 POSTS
Check your fuel pressure.
Go here: https://www.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator
Monday, January 15th, 2018 AT 5:37 PM
ANDREW LANE
Fuel pressure is 60 psi.
Tuesday, January 16th, 2018 AT 2:10 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,425 POSTS
How does the engine sounds when it is cranking over like it has compression? Here is a guide to help us confirm.
Cheers, Ken
Friday, January 19th, 2018 AT 11:28 AM
