Codes P1401 and P1409, crank no start?
FCERVANTES
  • 2002 FORD EXPLORER
  • 4.0L
  • V6
  • 4WD
  • 126,000 MILES
I have code p1401 and p1409, it will crank but will not start. I've tried disconnecting the DPFE sensor but nothing.
Thursday, August 10th, 2023 AT 4:24 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,425 POSTS
When you turn the key on without cranking the engine over can you hear the fuel pump turn on for about 5 seconds? Also, will the engine run on starting fluid?
P1401 - Differential Pressure Feedback EGR Circuit High Voltage:
P1409 - Exhaust Gas Recirculation System Leak Detected:
If you can hear the pump and it won't run on starting fluid we need to check for spark, this video will show you how:
https://youtu.be/baq_aEWNQ0Y
And please go over this guide can well:
https://www.2carpros.com/articles/car-not-running-advanced
Please go over these guides and get back to us.
Friday, August 11th, 2023 AT 10:50 AM
FCERVANTES
It has spark and fuel.
Friday, August 11th, 2023 AT 8:30 PM
KEN L
  • 43,425 POSTS
How does it sound when the engine is cranking over? We should do a compression test to make sure the engine is not hurt internally.
Please go over this guide:
Please go over this guide and get back to us.
Saturday, August 12th, 2023 AT 10:05 AM
