Coolant Capacity
CADDYDADDY2000
  • 2000 CADILLAC CATERA
  • 3.0L
  • 6 CYL
  • RWD
  • 164,000 MILES
Can you tell me how much coolant is needed to fill the radiator of my car?
Sunday, June 19th, 2016 AT 6:37 AM
SATURNTECH9
  • 30,869 POSTS
So did you change the radiator and your refilling the coolant system or just typing off the coolant level? There are no specs on how much coolant it takes to refill the radiator if you replaced it. There is only a total cooling system capacity which does not apply for that. Because there is coolant left in your engine hoses heater core etc. I would get two gallons of 50/50 coolant it will probably take At least a gallon and most likely a some of the other gallon as well. If you do not open the other gallon of coolant then you can always return it.
Sunday, June 19th, 2016 AT 9:42 AM
CADDYDADDY2000
Yes, I am flushing out the coolant system and wanted to know how many gallons of 50/50 to buy to refill it. Thank you!
Sunday, June 19th, 2016 AT 9:56 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome my suggestion should be fine then.
Sunday, June 19th, 2016 AT 10:17 AM
