Compression
PERFECTION 51587
  • 2002 KIA SPECTRA
  • 1.8L
  • 4 CYL
  • 194 MILES
After timing belt broke and replaced, zero compression cylinder one and two and thirty in cylinder three and ninety in cylinder four.
Sunday, December 10th, 2017 AT 3:10 PM
  • 108,524 POSTS
You have an interference engine. Basically, when it broke, the valves and pistons hit each other. I hate to say it, but I have never seen one survive it. From a professional stand point, replace the engine. The head is shot and chances are there is damage to the pistons. However, if you want to have your mechanic check it, maybe I am wrong. The only other thing is if you totally have the timing wrong.
Monday, December 11th, 2017 AT 5:53 PM
