HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Sentra
Engine
Wiring
SPONSORED LINKS
Coil wiring
ROC DUBONG
MEMBER
2004 NISSAN SENTRA
2.5L
4 CYL
2WD
AUTOMATIC
150,000 MILES
Number one coil gets hot and starts to smoke when its running the car then stops.
Wednesday, November 23rd, 2016 AT 3:09 PM
WRENCHTECH
MECHANIC
Have you tried swapping it with one of the other coils to see if the problem moves?
SPONSORED LINKS
Wednesday, November 23rd, 2016 AT 3:55 PM
KEN L
MASTER CERTIFIED MECHANIC
Hey Roc,
Replace the coil and the spark plug below it.
Please let us know happens so it will help others.
Best, Ken
Saturday, November 26th, 2016 AT 8:39 PM
Please
login
or
register
to post a reply.
Related Engine Wiring Content
Engine Wiring Diagram
Wiring Problem, Where The Signal To The Brain That Need Wiring Diagram Fuel Supply To The Engine For Can Find The Wiring Diagram For The...
Asked by
Anonymous
4 IMAGES
1995
NISSAN SENTRA
04 Nissan Sentra Spec-v
Fuel Injector In Cylinder 3 Is Not Spraying. Wireing And Ecm Check Out To Be Fine. Don't Know What To Do Next
Asked by
firesidefables
2004
NISSAN SENTRA
Vacuum Hose Diagram
I Have 1998 Nissan Sentra That Has A Code P0440 That Code Evaporative System Small Leak Didn't Have Time To Check Before Dark When Check...
Asked by
cherylp12
1 IMAGE
1998
NISSAN SENTRA
1996 Nissan Sentra Oxygen Sensor ?
My Car Has Never Given Me Any Problems.A Couple Of Days Ago, The Car Started To Shutter A Little. The Check Engine Light Now Comes On...
Asked by
cobwebsinattic
1 ANSWER
1996
NISSAN SENTRA
Ecu Pinout
Where Can I Get An Ecu Pinout For This 2/98 1.6l Dohc Ga16de Nissan Sentra Wiring Diagram?
Asked by
awtjr
1 ANSWER
6 IMAGES
1998
NISSAN SENTRA
VIEW MORE
SPONSORED LINKS
How to Use a Test Light
Throttle Body Actuator Service Toyota Prius 2
New Car Service
Online car repair manuals
