HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Electrical
Ignition Switch
Key
How much does it cost for a new coded ignition key?
WKNITTIG
MEMBER
2003 FORD EXPLORER
4.0L
V6
4WD
AUTOMATIC
218,000 MILES
Can you make one from the VIN? No one else has one with the code.
Thursday, January 12th, 2023 AT 1:56 PM
KEN L
MASTER CERTIFIED MECHANIC
Yep, you must get a coded key from the dealer, have your VIN ready. It should cost about $200.00.
Here are some blanks from Amazon with remotes for $19.95:
https://amzn.to/3iFedVC
SPONSORED LINKS
Friday, January 13th, 2023 AT 10:50 AM
Please
login
or
register
to post a reply.
Related Ignition Switch Key Content
Lost Ignition Key To 2003 Ford Explorer
Locked Out Car Lost Keys To Open Door N Start The Car.
Asked by
latriceward50
2003
FORD EXPLORER
Has That Chip In The Key
I Have A Ford Explore 1999 And It Has That Chip In The Key A Few People Told Me Its A Way To Bypass It Any Suggestion? When I Try To Start...
Asked by
greg91
1999
FORD EXPLORER
Key Wont Turn In Ignition Of My 98 Ford Explorer
I Disconnected The Battery To Clean The Posts And Connectors Put It Back Together And Drove It 3x With No Problem, Got In To Drive Again...
Asked by
suzanne
1998
FORD EXPLORER
Ford Car Key
I Lost My Car Key For A 2002 Ford Explore Can I Use A Locksmith To Change The Car Key Or Do Ihave To Get A Specific Key From The Dealer...
Asked by
Tekeisha
2002
FORD EXPLORER
2002 Ford Explorer Key Lock Cylinder
Key Will Not Turn Tried Everything As Far As Turning Wheel Etc. Can It Be The Lock Cylinder And If So How Do I Remove It Since It Is Stuck...
Asked by
jethro
1 ANSWER
2002
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Battery Replacement Ford
Battery Replacement Dodge
Online car repair manuals
