1999 Chrysler Town and Country serpentine belt
PIZZAALWAYS
  • 1999 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • 85,000 MILES
Belt keep coming off in wet weather
Saturday, December 15th, 2007 AT 3:16 PM
  • 31,937 POSTS
Hi there,
This may be a belt that has stretched and the adjuster can not keep adequate tension up to it, or some minor misalignment in a pulley, allowing it to walk off when wet and a bit slippery, don't use any belt grip in a can, this will only make matters worse, check for a worn belt and check for any pulley misalignment.
Mark (mhpautos)
Saturday, December 15th, 2007 AT 3:56 PM
JTODD43
Don't let your mechanic use a cheap aftermarket belt. Ask for a Gates belt, and replace the tensioner with an OEM from the dealer. It might cost a little more, but definitely worth it!
Tuesday, December 18th, 2007 AT 6:38 AM
