HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chrysler
Town and Country
Engine
Camshaft
Timing
SPONSORED LINKS
1997 Chrysler Town and Country Starting
MICKEY DEE
MEMBER
1997 CHRYSLER TOWN AND COUNTRY
6 CYL
FWD
AUTOMATIC
153,385 MILES
The engine cranks three to four times before it starts. This just happened overnight. It usually starts after one crank. Any suggestions.
Thanks
Friday, July 17th, 2009 AT 9:02 AM
BMRFIXIT
MECHANIC
Start by checking it for tune up
do fuel pressure check
SPONSORED LINKS
Sunday, July 19th, 2009 AT 12:02 AM
MICKEY DEE
MEMBER
Already had tune up and the fuel pressure tested, also had the injectors cleaned. Any further suggestions.
Tuesday, July 28th, 2009 AT 2:58 PM
Please
login
or
register
to post a reply.
Related Camshaft Timing Content
Timing Mark Alinment
I Need The Timeing Aliment Mark Set Up For Mazda 626 96 Was Replacing Water Pump And Belt Sliped When I Moved The Hamonic Pully
Asked by
gassed001
1 ANSWER
1998 Chrysler Town And Country 1998 Town And Country...
Engine Mechanical Problem 1998 Chrysler Town And Country 6 Cyl Two Wheel Drive Automatic I Have A 1998 Town And Country That Will...
Asked by
hmzjacks
1998
How Easy Is It To Replace Both Rear Shims And Front...
I Replaced The Struts And And Shocks And Took It For Alignment And Was Told They Could Not Do It Because These Two Things Need To Be...
Asked by
jubis
2002
1997 Chrysler Town And Country Air Intake Temperature...
I Wondered If Anyone Can Tell Me Where The Air Intake Temperature Sensor(iat, Ait, Or Mat Sensor) Is Located On My 1997 Town And Country....
Asked by
poolenglish
1997
1997 Chrysler Town And Country Serpentine Belt
Engine Mechanical Problem 1997 Chrysler Town And Country 6 Cyl Two Wheel Drive Automatic The Serpentine Belt On My Van Fell Off And I...
Asked by
sanoskei
1 ANSWER
1997
VIEW MORE
SPONSORED LINKS
Camshaft Sensor Replacement
Engine Noises
Intermittent Misfire
Online car repair manuals
