HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chrysler
PT Cruiser
Engine
Starter
2005 Chrysler PT Cruiser starter
SOFTASILK
MEMBER
2005 CHRYSLER PT CRUISER
Electrical problem
2005 Chrysler PT Cruiser 6 cyl Front Wheel Drive Automatic
how to tap a starter to get to work
Monday, November 8th, 2010 AT 7:46 AM
WRENCHTECH
MECHANIC
Get a small hammer and tap on the body of the starter while someone else is holding the key is "start" position.
This is only a testing procedure that works SOMETIMES.
SPONSORED LINKS
Monday, November 8th, 2010 AT 7:53 AM
Please
login
or
register
to post a reply.
Related Starter Content
Low Starter Cranking Voltage
What Causes Low Starter Cranking Voltage?
Asked by
YUGGIB36
2005
CHRYSLER PT CRUISER
VIDEO
Starter and Set Points Gap!
Instructional repair video
GUIDE
Starter
An engine starter is constructed as a high torque, high amperage 12 volt motor fitted with an electrical solenoid and Bendix gear which is used to rotate an engine between...
2005 Chrysler Pt Cruiser Engine Support Plate Removal...
How Do You Remove The Engine Support Place That In In Front Of The Tensioner In Order To Replace The Timing Belt?"
Asked by
franiekay
2005
CHRYSLER PT CRUISER
Lopes Or Cuts Out Around 3500 Rpm, In Neutral And In...
Lopes Or Cuts Out Around 3500 Rpm, In Neutral And In Drive. Any Ideas? 2.4 Non Turbo.
Asked by
Anonymous
2005
CHRYSLER PT CRUISER
O2 Sensor And Fuel Trim
This Is A Technical Question. Why At Fully Open Throttle The O2 Sensor Goes Rich? Does It Stay Rich All Time When The Throttle Is Fully...
Asked by
zemorzemor
2006
CHRYSLER PT CRUISER
Pcm Testing
What I Should Use To Back Probe The Pt Cruiser Pcm Without Damaging Or Spreading The Connectors
Asked by
zemorzemor
2006
CHRYSLER PT CRUISER
VIEW MORE
SPONSORED LINKS
Starter Motor Replacement
Online car repair manuals
