2002 Chrysler PT Cruiser PCM relearn procedure
PVASSAR
  • 2002 CHRYSLER PT CRUISER
Engine Performance problem
2002 Chrysler PT Cruiser 4 cyl Two Wheel Drive
I need to know what the computer relearn procedure.
Saturday, March 13th, 2010 AT 8:06 PM
CARADIODOC
  • 33,748 POSTS
Basically you just drive it and the computer will start out from pre-programmed fuel delivery values. As you drive, it will see when the exhaust is too rich or too lean and it will make adjustments. Later, it will use the new learned values so it doesn't have to readjust so much. You won't notice that taking place.
What you WILL notice is the engine likely will not idle fast enough so it will stall when you come to a stop. The computer must relearn "minimum throttle" so it will know when it must be in control of idle speed. It takes a reading from the throttle position sensor when it knows your foot is off the gas pedal. It knows that by the fact the car is coasting. It knows the car is coasting when intake manifold vacuum is higher than normal. You can make that happen by snapping the throttle open and releasing it quickly, but the computer wants to see high vacuum for seven seconds. To meet the conditions for this relearn to take place, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the brake or gas pedals.
Caradiodoc
Tuesday, March 23rd, 2010 AT 3:04 AM
PATTI JEPSEN
Chrysler Drive Cycle Information
All Monitor Drive Trace
Pre-Conditioning Requirements:
- MIL must be off
- Cold start (Note: cold start temperature is undefined)
Driving Procedure
1) Warm engine up for five minutes (must reach closed loop)
2) Drive (with steady throttle) at a speed between 40 and 60 mph for 8 minutes.
3) Stop and idle for 3 minutes.
4) Drive (with steady throttle) at a speed above 20 mph for 2 minutes.
5) Turn key off, leave off for ten minutes (to run O2 sensor heater monitor).
Note: Due to the limited preconditions provided with this drive trace, NCVECS recommends using the monitor
specific drive traces for Chrysler vehicles.
Catalyst Monitor Drive Trace
- MIL must be off.
- No DTCs present.
- Fuel level is between 15% and 85% full.
- ECT above 70Â F.
- Engine must have run at least 90 seconds
- Engine between 1,350 & 1,900 rpm.
Driving Procedure
1) Idle vehicle for five minutes (to reach closed loop operation).
2) Drive with a steady vehicle speed between 30 and 45 mph for 2 minutes.
EGR System Monitor Drive Trace - Vacuum controlled
- MIL must be off.
Driving Procedure
2) Drive with a steady vehicle speed between 40 & 60 mph for 8 minutes.
EGR System Monitor Drive Trace - Electronic
- MIL must be off.
- MAP must be between 0-60 KPa.
- Engine speed between 500-850 rpm.
- ECT is above 180Â F (90Â C).
- No misfire temporary (pending) or matured fault present.
- A/C clutch, PS Switch and Cooling fans do not change state (turn off).
Driving Procedure
1) Idle vehicle for five (5) minutes (to reach closed loop operation).
2) Drive with a steady vehicle speed between 40 & 60 mph for 2 minutes.
3) Idle vehicle for three (3) minutes.
Sunday, August 21st, 2016 AT 12:26 PM
PATTI JEPSEN
Note: This monitor evaluates EGR flow based on a change of engine roughness (idle stability).
Conditions causing un-stable idle will prevent this monitor from running.
Evaporative System Monitor Drive Trace
Trace 1: Standard Type
- MIL must be off.
- No Evaporative DTCs present.
- Fuel level is between  and full.
(Note: monitor may still run with tank fill between 15% and 85%).
Driving Procedure
Trace 2: Leak Detection Pump
- MIL must be off.
- Fuel level is between 30 & 85 % full.
Driving Procedure
1) Cold soak vehicle, start and idle vehicle for 4 minutes.
2) Drive in-town (stop and go) for 5 minutes, using smooth accelerations and decelerations.
3) Stop and idle vehicle for 4 minutes.
O2 Sensor Monitor Drive Trace
- MIL must be off.
Driving Procedure
2) Drive with a steady vehicle speed above 25 mph for 2 minutes.
3) Stop and idle for 30 seconds.
4) Smoothly accelerate to a speed between 30 and 40 mph.
5) Repeat steps 3 & 4 five (5) times.
O2 Sensor Heater Monitor Drive Trace
- MIL must be off.
Driving Procedure
2) Shut engine off and leave vehicle off for ten minutes.
Sunday, August 21st, 2016 AT 12:28 PM
