1999 Chevy Cavalier (No Power To Anything Now)
DECOY
  • 1999 CHEVROLET TRUCK
My 1999 cavalier is going crazy. I have to jump it to start it and nothing has power. No radio, gauges, wipers, lights, clunky shifting, and hard idling. The check engine light is on if that helps. The fuses all look good. Any idea where to start?
Saturday, July 8th, 2006 AT 2:39 AM
MIKEYBDMAN
  • 623 POSTS
Take the battery to your local parts store and have them test it. If it is bad, replace it. If it just needs charging, then charge it and then take the whole car down there to have the charging system checked out. You may have a bad altenator, or a bad connection to the battery or engine ground.
Good luck
Saturday, July 8th, 2006 AT 3:06 PM
MFAIRCHILD12
Also check the buss fuse under the hood. Sounds like the main buss fuse from the battery leading to the inside has blown. It should be between 40 60 amp fuse.
Wednesday, July 19th, 2006 AT 11:50 AM
