1992 Chevy Truck Wont Start
DWEST052706
  • 1992 CHEVROLET TRUCK
  • V8
  • MANUAL
  • 100,000 MILES
I was driving my truck and it sputtered a little then just quit running. I had plenty of gas but it wouldnt start again. I replaced the fule filter and there's gas coming out when I turn it over. When the filter is hooked up all the way the truck still wont start. When I spray starter fluid in the carburator it starts right up but stops as soon as the starter burns off. HELP, I'm not in the position to tow it to a dealer. Hope you can help.
thanks
Wednesday, January 23rd, 2008 AT 6:41 PM
FISHERMAN
  • 937 POSTS
Hello !
Check if the carburator has another filter (inline) right at the fuel line connector, if so, clean it and be sure that its "clear" then check the float needle could be "stuck closed".
Good Luck and let us know!
Wednesday, January 23rd, 2008 AT 7:32 PM
CORY GRABEEL
My 93 did the same thing, Im going to replace the fuel pump today, hopefully that does the trick.
Friday, January 25th, 2008 AT 4:17 PM
