2001 Chevy Tahoe trouble codes
RONSNON
  • 2001 CHEVROLET TAHOE
  • V8
  • 4WD
  • 60,000 MILES
Car has codes
0100
0101
0102
0103
0104
0105
0106
0107
0108
0109
car runs good. Scanner say it might be a dirty air filter. Any help would be appriciated
RON
Monday, January 21st, 2008 AT 3:44 PM
FISHERMAN
  • 937 POSTS
Hello Ron !!
The codes:
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0101 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
Well looks like your Mass Air Flow sensor its dirty or malfunctioning, remove it and clean it (do it with care) clear the codes and see if they comeback.
Go to your local auto store and get electrical contact cleaner. Spray it thru the honey combo and over the diodes to get it good and clean. It will dry pretty quickly
thanks a lot for your donation and good Luck!
let us know if that solve your problem !
https://www.2carpros.com/forum/automotive_pictures/576_chevy_tahoe_Maf_sensor1_1.jpg
Monday, January 21st, 2008 AT 3:53 PM
