1999 Chevy Tahoe
BOBDOC64
  • 1999 CHEVROLET TAHOE
Electrical problem
1999 Chevy Tahoe V8 Four Wheel Drive Automatic
Why wont my 99 chevy tahoe start?
It has good spark and good fuel pressure kicks back threw the intake. Does start occasionaly. Only after sitting about two to three days does it have this problem.
Additional Details
Battery is new coil is new It has good spark and good fuel pressure kicks back threw the intake. Does start occasionaly. Only after sitting about two to three days does it have this problem.
Saturday, January 23rd, 2010 AT 12:48 PM
  • 108,289 POSTS
Are you getting power to the fuel injectors? Have you checked timing and engine compression? Finally, was the check engine light on? This could be something as simple as a crank sensor.
Sunday, January 24th, 2010 AT 12:55 AM
BOBDOC64
Compression, fuel, spark is good, timing is good. Problem happens if truck sits for two days or more. Then you could go out next day and truck would start as if no prblem. When it does not start it cranks, and almost locksup, you would swear it is a ign. Problem. How about a crank sensor.
Sunday, January 24th, 2010 AT 5:00 PM
  • 108,289 POSTS
It could be a crank sensor, but I would think that would have set the check engine light. WHen it doesn't start, are you sure you're getting spark? If you are, then the crank sensor is fine. Also, I will assume you checked the injectors with a noid light or = to make sure they are firing too.
Monday, January 25th, 2010 AT 7:40 AM
BOBDOC64
Thanks for all your help wish everybody would go back to basics on diagnosis.I replaced distributor cap and router a year ago, crabcap. What I found was, brass terminals on cap turned green indicating water got in and was wet when I removed it new cap and rotor pricey as they are solved the problem. Also when checking crank sensor did not ohm check good from terminal a to c. Old sensor 20.00 compared to 5.00 for new. Replaced it before I put cap and rotor on swore it was gonna solve my problem. Cap and rotor was the problem!
Saturday, January 30th, 2010 AT 2:25 PM
  • 108,289 POSTS
I'm glad you found the problem. It's funny. WHat you said couldn't be more accurate. Cars have become so involved that is causes people who deal with them every day to forget the basics. I'm sorry about that. I just delt with one that a person had over 1000 dollars in it with sensors, solenoids. And couldn't get rid of a miss. I told him to start the car and spray water on the plug wires since the problem was worse when it was wet out. That is a perfect example of back to basics. It cost him a 15.00 set of plug wires after he saw them light up when wet. He was happy to find the problem, but mad about how simple the problem was. Your advice is good. I miss the good old days.
Take care, thanks for using 2carpros. Com, and thanks for the usefull advice.
Saturday, January 30th, 2010 AT 11:49 PM
BOBDOC64
Heres a tip for anyone who has put rotors on the new colorodo's. After changing front brake rotors two wheel drive. The dredded abs light comes on. Look at were the bearings at the abs ring is at. Its actually part of a seal pop seal out with small thin screwdriver and you'll see it became bent. Flatten as best as possible try to keep it as true as possible. Reinstall damage came from getting bearing out of hub. Will save tons of money because seal is reluctor wheel. Pain in the butt job doing twice. Nothing to loose by tryin to straighten old reluctor wheel/seal. Because new bearing comes with the relutor wheel. Look carefully and be careful! Good luck! Have had success doin this!
Sunday, January 31st, 2010 AT 2:30 PM
  • 108,289 POSTS
Thanks for the good advice with.
Monday, February 1st, 2010 AT 7:31 PM
