WHEN I TURN THE KEY ALL THE DUMMY LIGHTS COME ON AS USUAL BUT THE ENGINE MAKES NO NOISE. I IMMEDIATELY THOUGHT IT WAS THE BATTERY SO I TOOK IT OUT AND HAD IT TESTED AND IT WAS FINE SO I THEN PROCEEDED TO THE STARTER AND DID THE SAME TO FIND OUT ITS NOT THAT EITHER. SO I PUT EVERYTHING BACK IN AND CHECKED ALL THE FUSES AND RELAYS BUT THEY ARE ALL GOOD AS WELL. SOMEWHERE ALONG THE WAY I AM LOSING VOLTS. I CALLED AND SPOKE TO A MECHANIC AND HE SAID THAT IT COULD EITHER BE THE IGNITION SWITCH OR POSSIBLY THE NEUTRAL SAFETY SWITCH, IS HE CORRECT OR DO I HAVE BIGGER ISSUE ON MY HANDS? I AM COMPLETELY STUMPED AT THIS POINT AND EXTREMLY PISSED OFF CAUSE THIS IS MY ONLY VEHICLE. ANY INFORMATION YOU COULD GIVE ME WOULD BE MUCH APPRECIATED.
SPONSORED LINKS
Do you
have the same problem?
Sunday, June 8th, 2008 AT 10:06 AM
