2000 Chevy Lumina back door
RDRNER9
  • 2000 CHEVROLET LUMINA
  • 6 CYL
  • 143,000 MILES
Needs the door latch replaced. It is stuck closed keeping the door from closing This has happened before when I have used the chid safty lock. How much should it cost to replace or is it something a non perfessional could do with a little instruction
Saturday, January 9th, 2010 AT 12:16 PM
  • 108,544 POSTS
Actually, it shouldn't be too hard for you. Once you remove the door panel, it is just a matter of unbolting the latch and removing the linkage to it. You should be able to do it.
Have you taken a look at it?
Tuesday, January 19th, 2010 AT 12:20 PM
