1994 Chevy Lumina Dash Lights Stay On
MVOLOPSKI
  • 1994 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 182,000 MILES
The car has always had the dash illumination lights come on for about 30 sec when the doors are first closed then go off. Like they were on a time delay. Today I noticed that they were stuck on. When they are on they cannot be controlled by the dimmer, the only time they go off is when the dashlight dimmer is moved to turn on the interior lights, then the dash lights will go off. The lamps will come back on when the interior lamps are turned off. When the tailights or headlights are on the dash lights can be dimmed by the dimmer and seem to function normally until the ignition is turned off then they stay on.
Friday, November 28th, 2008 AT 8:23 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,543 POSTS
Hi, does your car have analog gauges or lcd screen?
Saturday, November 29th, 2008 AT 1:20 AM
MVOLOPSKI
Analog guages
Saturday, November 29th, 2008 AT 9:12 PM
KEN L
  • 43,543 POSTS
Hi, the dash lights are controlled by the BCM. It sounds like yours has shorted and needs replacing.
Sunday, November 30th, 2008 AT 1:28 AM
HELMETHAIR78
That is the same problem I am having with my 92 Lumina.
When you say BCM are you talking about the body control module? If so is there are two of them. Would it be the break or cruise bcm?
Saturday, February 14th, 2009 AT 7:08 PM
KEN L
  • 43,543 POSTS
Hi, it would be the daytime running lights modual
Monday, February 16th, 2009 AT 11:02 AM
