Throttle position sensor
ROBRIUAR
  • 2006 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 103,000 MILES
How do I replace an app sensor or throttle position sensor on my 2006 chevy impala? What does the throttle position sensor look like.
Saturday, January 22nd, 2011 AT 1:57 PM
DOCFIXIT
  • 18,828 POSTS
APP sensor connected to pedal see diagram is there aMIL on? What was code?
Saturday, January 22nd, 2011 AT 3:54 PM
ROBRIUAR
The code said throttle sensor damaged or malfunctioning. All the repairs say it is part of another piece that should be replaced as a whole
Saturday, January 22nd, 2011 AT 4:54 PM
DOCFIXIT
  • 18,828 POSTS
Please provide code in P0xxx format and engine size
Saturday, January 22nd, 2011 AT 5:12 PM
BROGEE
  • 6 CYL
  • 9,845 MILES
Where is the throttle position sensor located?
Sunday, July 28th, 2019 AT 6:42 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle is equipped with accelerator pedal position (APP) sensor, it is located above the accelerator pedal. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
YUNGBLOOD04
Engine Performance problem
2006 Chevy Impala 6 cyl Automatic 76000 miles
Im not really too familiar wit cars and how to fix them but my check engine light came on I got the code it was my throttle position sensor so pep boys told me dey couldnt take sensor off without replacing whole throttle body so they replace the whole throttle body for $500 I just got new spark plugs and wires but they didnt change fuel filter during tune up all I wanna know is what is causing my car to shake when I come to a stop, why am I smelling antifreeze when I open hood, and why am I losing power and why do rpms keep jumping do any one have a answer for those questions plz help
Sunday, July 28th, 2019 AT 6:43 PM (Merged)
LEGITIMATE007
  • 5,121 POSTS
Sounds like a blown head gasket. Check your coolant to see if there is coolant, fill it up and fill the resevoir.
MJACOBS30
  • 2001 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 144,000 MILES
Is there a way to get a picture of where the TPS is located on my 2001 Impala? I'm going to replace it, but I don't know where it's located.
Please help if you can.
DOCFIXIT
  • 18,828 POSTS
If 3.8L
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_280.jpg
CRAZIYANKEE
  • 106,000 MILES
When I first start out with the car and press the accelerator it will not do anything for a little bit and then it will take off it also sometimes surges a little bit earlier the codes for the throtttle position sensor were showing up now the check engine light does not come on I am wondering if this is the throttle position sensor or throttle acutator control and where about they are located on the engine
HMAC300
  • 48,601 POSTS
The throttle posistion sensor is on the throttle body assy. The throttle actuator is off the gas pedal. Check for stuff jammed under your pedal like a floor mat not letting it operate right. If not have it rescanned to see if it pops up or not. An auto parts tore scaner will not pic up the actuator.
CRAZIYANKEE
Somebody told me that I cant just replace the tps I have to replace the whole assembly as a unit is that true or is just a simple sensor to replace and which is it most likely to be the tps or tac
HMAC300
  • 48,601 POSTS
The tps is replaceable but make sure that that is the problem before you wwaste your money. Try cleaning your throttle plate on both sides with choke cleaner and the iac hole as it gets gummy and will stick alot of times. Do that first cause it's cheap and you may not need a sensor. Also clean around the tps sensor where it meets the throttle plate.
CRAZIYANKEE
Ok thanks do you have a diagram of tps sensor and where it meets the throttle plate?
HMAC300
  • 48,601 POSTS
Depending on engine size it will be where one of the two arrows are. Thee are three wires leading to it.
