HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Impala
Engine Cooling
Coolant Temperature Sensor
SPONSORED LINKS
Engine Coolant Temperature Sensor
TONY ARNOLD
MEMBER
2003 CHEVROLET IMPALA
Engine Cooling problem
2003 Chevy Impala 6 cyl Front Wheel Drive Automatic
Where is it located? Can it be easily removed and replaced?
Do you
have the same problem?
Tuesday, October 28th, 2008 AT 9:35 AM
DENNYP
MECHANIC
Here is a guide to help you see what you are in for when doing the job.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Here is the location on your car.
Check out the diagrams (Below)
Cheers
Image (Click to make bigger)
SPONSORED LINKS
Tuesday, October 28th, 2008 AT 11:03 AM
JABERNATHY2106
MEMBER
2001 CHEVROLET IMPALA
6 CYL
2WD
AUTOMATIC
97,500 MILES
2001 Chevy Impala 6 cyl Two Wheel Drive Automatic 97500 miles
How do you change your coolant sensor, or where can I find out how to go about doing so?
Tuesday, April 10th, 2018 AT 3:57 PM (Merged)
LEGITIMATE007
MECHANIC
I have a diagram with the simple instructions and location of the ect, (engine coolant temp sensor)
LEGITIMATE007
MECHANIC
DNORRIS38
MEMBER
6 CYL
FWD
AUTOMATIC
116,426 MILES
Where is the Engine coolent sensor located?
SPONSORED LINKS
MERLIN2021
MECHANIC
On 3.8 As in diagram:
MICKEY-D
MECHANIC
6 CYL
2WD
AUTOMATIC
28,544 MILES
Could you please give me the location of the coo;ant level sensor for the 3.4 engine?
BLUELIGHTNIN6
MECHANIC
Engine coolant temperature (ECT) sensor is located near the coolant outlet, on left rear of engine.
Please
login
or
register
to post a reply.
Related Coolant Temperature Sensor Content
Engine Coolant Sensor Problem
Replaced Thermostat, Temperature Coolant Sensor, Fuel Filter. Car Was Have Troubles When You Reach 40-50 Mph Rpms And Gas Pedal Bouncing Up...
Asked by
whitebh
4 IMAGES
2005
CHEVROLET IMPALA
VIDEO
Coolant Temperature Sender Replacement
Instructional repair video
GUIDE
An engine coolant temperature sensor also described as an ECTS (electronic coolant temperature sensor) is designed to tell the car's computer how hot the engine is running....
Where Is The Coolant Sensor Located On The Car
Asked by
key key
1 ANSWER
2002
CHEVROLET IMPALA
2005 Chevrolet Impala Engine Coolant Temperature...
I Have Been Having Many Problems With My Cooling System. Two Years Ago, My Ex Put In One Of Those 'stop Leak' Crayons To Fix What We...
Asked by
Sandarella
1 ANSWER
2005
CHEVROLET IMPALA
2001 Chevy Impala
Engine Cooling Problem 2001 Chevy Impala 6 Cyl Front Wheel Drive Automatic I Put A New 195 Thermostat And Coolant Temperature Sensor....
Asked by
psthereal
1 ANSWER
2001
CHEVROLET IMPALA
2004 Chevy Impala Temperature Sensor
The Car Heats Up Rather Quickly The Fans Do Not Seem To Be Coming On At All Fuses Seem Fine Not Sure About Relays Could This Be The The...
Asked by
catway
2004
CHEVROLET IMPALA
VIEW MORE
SPONSORED LINKS
Coolant Temperature Sensor Replacement
Check Engine Light Safe to Drive?
Online car repair manuals
