HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Cavalier
Engine Cooling
Radiator
Replace/Remove
1997 Chevy Cavalier Radiator Replacement
GINAKLATT
MEMBER
1997 CHEVROLET CAVALIER
4 CYL
FWD
AUTOMATIC
125,000 MILES
How much should it cost to replace the radiator in this car?
Thursday, July 17th, 2008 AT 4:53 PM
OBXAUTOMEDIC
MECHANIC
It can cost up to about $700. That is on the high side and based on a labor rate of $75 an hour and a radiator for a 2.4 L engine
SPONSORED LINKS
Thursday, July 17th, 2008 AT 5:18 PM
Please
login
or
register
to post a reply.
Related Radiator Replace/Remove Content
Radiator Replacement?
How Do I Drain Coolant From The Coolant System? The Car Is Overheating And The Heater Does Not Work Only The Fan Works. I Need To Know How...
Asked by
crystal gayle resinger
1 ANSWER
14 IMAGES
2002
CHEVROLET CAVALIER
VIDEO
Radiator Replacement Kia Sportage
Instructional repair video
GUIDE
A radiator removes heat from the engine through thermal heat exchange using coolant as a conductor and is usually located in the front of the vehicle under the hood. A ...
Radiator
How To Replace A Radiator In A 2002 Chevy Cavalier?
Asked by
starjones21
5 IMAGES
2002
CHEVROLET CAVALIER
94 Cavalier -- Water Shoots Out Of Radiator
Some Background: 1. Bought Used With A Replaced Engine. 2. Replaced Head Gasket Last Fall. 3. Last Month Started Running Hot. Checked...
Asked by
colobleu
1 ANSWER
1994
CHEVROLET CAVALIER
1994 Chevy Cavalier 99,688 Bottom Radiator Hose Is...
My 1994 Chevy Cavalier Rs The Bottom Hose Is Cool When Running The Upper Radiator Hose Is Warm Also The Radiator Cap Isnt Hot After Going A...
Asked by
durham35
1 ANSWER
1994
CHEVROLET CAVALIER
Will A Car Stall Out If Radiator Cap Is Faulty And Not...
Discovered Radiator Cap Glued On. Car Has Been Stalling Out When It Warms Up.
Asked by
bopples70
2000
CHEVROLET CAVALIER
VIEW MORE
SPONSORED LINKS
Radiator Replacement Mercedes Benz
Upper and Lower Radiator Hose Replacement
Radiator Hoses and Thermostat Replacement
Online car repair manuals
