HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Cavalier
Trouble Codes
P Codes (Powertrain)
P0100 - P0199
P0134
SPONSORED LINKS
1997 Chevy Cavalier Code PO134
SCOTTSBAYGIRL
MEMBER
1997 CHEVROLET CAVALIER
4 CYL
2WD
AUTOMATIC
225,000 MILES
Code PO134 appears, comes back even after changing O2 Sensor
Saturday, February 6th, 2010 AT 4:38 PM
MECHANIC
Hi there,
You will need to check the circuit back to the ECU, I feel that this is a wiring fault.
Mark, mhpautos
SPONSORED LINKS
Saturday, February 6th, 2010 AT 4:43 PM
SCOTTSBAYGIRL
MEMBER
It's fine untill engine reaches operating temperature then the PO134 code comes back again
Saturday, February 6th, 2010 AT 4:50 PM
MECHANIC
Hi there,
P0134 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
I would still be checking the continuity back to the ECU as you say the sensor has been replaced, otherwise you may be looking at an ECU internal fault.
Mark, mhpautos
Saturday, February 6th, 2010 AT 8:20 PM
Please
login
or
register
to post a reply.
Related P0134 Content
1997 Cavaleir Dtc P0171
Car Runs Fine Except For A Slight Miss After Operating Temp. Has Been Reached. When You Shut Car Off And It Sets For A Short Period Say 10...
Asked by
rjg71
1 ANSWER
1997
CHEVROLET CAVALIER
1998 Chevy Cavalier Po171 And Very Rich Fuel...
My 98 Cavalier Is Failing Emissions, Started Out As Po171 Code, Then Others, Long Story Short, Every Single Sensor Has Been Replaced...
Asked by
lwico
1998
CHEVROLET CAVALIER
2001 Chevy Cavalier P0141 Code
Hello. Midas Replaced Exhaust System 3 Days Ago. 8 Miles Later My Check Engine Light Came On. Went To Autozone Said It Was P0141. Went...
Asked by
jmjm2
2001
CHEVROLET CAVALIER
2002 Chevy Cavalier P0172 System To Rich
I Just Replaced The Fuel Pump And Fuel Filter And The Car Is Now Running Great But I Have The Check Engine Light On Again, Ran Codes The...
Asked by
ghill8950
2002
CHEVROLET CAVALIER
P0300 And P0141 Error
I Have A 03 Chevy Cavalier. It Randomly Will Begin Misfiring (thus The P0300). Other Times It Runs Fine. I Replaced The Plugs, Boots To...
Asked by
plmcguir
1 ANSWER
2003
CHEVROLET CAVALIER
VIEW MORE
SPONSORED LINKS
Check Engine Light Safe to Drive?
Code Read Retrieval/Clear
Code Read Retrieval/Clear - Dodge Stratus
Online car repair manuals
