1994 Chevy Cavalier Antifreeze/Coolant leek
NATEMAN109922
  • 1994 CHEVROLET CAVALIER
  • 4 CYL
  • 100,987 MILES
I am haveing a problem with a coolent leek coming from around the oilpan near the bottom of the car. I replaced the thermostat with a new oem one. What els could be the problem?
Friday, July 18th, 2008 AT 4:32 AM
  • 31,937 POSTS
Hi there,
There are a number of places that the coolant can be coming from, so you should get a cooling system pressure test doe, this will help locate your problem.
Mark (mhpautos)
Friday, July 18th, 2008 AT 4:59 AM
NATEMAN109922
Hi I found the leek is coming from the oil pan and I have a good amount of coolent in my oil pan mixed with the oil what could this mean?
Monday, July 21st, 2008 AT 3:56 AM
  • 31,937 POSTS
Hi there,
You will want to be doing a check for a head gasket problem first as coolant in the sump is usually from a head problem.
Mark (mhpautos)
Monday, July 21st, 2008 AT 4:55 AM
