Convertible top powers down normal, but will not come back up.
Saturday, June 20th, 2009 AT 4:10 PM
MECHANIC
THe same motor does both jobs. The polarity is reversed to reverse the engine. Check to see if the motor is getting power when you try to put up the top. If it isn't, chances are the switch is bad.
