2001 Chevy Blazer Battery Drain
JCHEFBOYARDEE
  • 2001 CHEVROLET BLAZER
  • 6 CYL
  • 93,000 MILES
I suspect that the courtesy mirror lamps in the visors are draining the Battery. The hinges are broke on the visor mirrors and I want to disable the lamps. What fuse should I pull to disable these lamps? By the way, the car sits days without being driven and the Battery is near new and was check, results indicated good on the Battery.
Tuesday, June 2nd, 2009 AT 11:10 AM
  • 108,517 POSTS
AS far as the fuse, you need to check the owner's manual. Once you remove it, here is a how to for checking for draw on the battery.
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Let me know what you find.
Wednesday, June 3rd, 2009 AT 6:56 PM
