2003 Chevy Astro Defrost only
TJWRIGHT
  • 2003 CHEVROLET ASTRO
  • 6 CYL
  • AWD
  • 69,000 MILES
I have 2003 Chevy Astro Van, I can not get air (hot/cold) to blow out the dash or on to the floor.
The blower is working. I don't think that the AC is worker, due to the same problom.
Monday, December 7th, 2009 AT 12:30 PM
  • 108,454 POSTS
What you are looking for here is a vacuum leak. The vent doors are actuated by vacuum. If there is a leak, it defaults to the defroster. Check under the dash and under the hood for leaks. With the engine running, you may actually hear a hissing sound where the leak is located.
Let me know if you have other questions, and thanks for using 2carpros. Com.
Monday, December 21st, 2009 AT 7:55 AM
