1999 Chevy Astro Miss when cold
SAMPHOTO
  • 1999 CHEVROLET ASTRO
  • 6 CYL
  • 247,583 MILES
Some days. 1 out of 6 van will miss in morning
high humidity & rainy days van will miss for sure.
9 times out of 10 goes away after warm up.
coil has been replaced recently.
doesn't throw off any codes.
fuel pump replaced 2 yrs ago
plugs and wires ok
I'm planning on a compression test
and a fuel pressure test this weekend
possibly a scope check.
any ideas?
Tuesday, October 13th, 2009 AT 3:59 PM
  • 108,465 POSTS
My first guess when you say it is worse on damp days is either the distributor cap or plug wires. You said they were okay. How did you check them?
Wednesday, November 18th, 2009 AT 10:30 AM
SAMPHOTO
The plug wires were replaced 6 months ago
after 1 came apart in my hand. New duralast installed
high condensation areas seem to play a part.
I just drove from a heavy fog area and it missed all day. [ 5 hrs of driving ]
>>>It does not miss under acceleration.
It will miss immediately after letting off gas
and while cruising. <<<
Twice it has missed all day. Both times on long road trips. Normally driving around town it will miss for 20 minutes in the morning and run fine after that.
Most other days it will not miss at all.
I have installed a new dist cap so I'll wait and see.
I did not see any cracks in the old dist cap
Ignition module and crank sensor are recent.
thanks for your help
Tuesday, November 24th, 2009 AT 3:20 PM
