1999 Chevy Astro fuel filter replacement
DANFISCHER
  • 1999 CHEVROLET ASTRO
  • 6 CYL
  • 92,031 MILES
Location of fuel pump.
replacement instructions.
Saturday, November 28th, 2009 AT 9:03 AM
JDL
  • 16,098 POSTS
Welcome to the forum, the fuel filter is located under the vehicle, driverside, in front of fuel tank, in the fuel line. My info shows a threaded fitting on both ends, use a couple of wrenches. Make sure there is no pressure on the system, before you take anything loose. You may need to loosen the gas cap. The pump is in the gas tank.
Saturday, November 28th, 2009 AT 9:29 AM
