Rubbing noise
DRTBKRYZ
  • 1995 CHEVROLET ASTRO
Hello, I have a 95 awd astro, my problem is a rubbing noise that comes and goes in the front end, it kind of pulses if you know what I mean. Do you think its the hub bearing? My transaxles are fine I need an alignment but want to fix this problem beforehand, thanks guys
Monday, February 18th, 2008 AT 5:09 PM
BLACKOP555
  • 10,371 POSTS
Might be your wheel bearings but first does it stop when the brakes are pressed?
Also check to see that the dust shield isnt bent causing that sound.
Friday, March 21st, 2008 AT 12:50 PM
JOSEPHANGELAMARIED
1998 Chevy astro. Driver side floor board has thumping noise and it's even in the steering wheel. I need help to find what it is exactly.
Thursday, December 6th, 2018 AT 1:16 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,434 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Friday, December 7th, 2018 AT 9:15 AM
