Check Engine Light on with codes P0300, P0302 and P0303?
OREO101
  • 2005 FORD EXPEDITION
  • 5.4L
  • V8
  • 4WD
  • 200,000 MILES
My car is due for inspection in PA.
I get codes P0300, P0302 and P0303.
Showing misfires.
I will replace spark plugs and coil packs for #2 and #3 cylinders.
I did the other plugs and coil packs for other cylinders.
Luckily the plugs have been replaced before, so the plugs are 1 piece and not the dreaded original 2-piece that had possibility of breaking off in cylinder.
Could there be other causes for these CEL codes?
Thanks!
Sunday, March 24th, 2024 AT 8:08 PM
BORIS K
  • 765 POSTS
The most common causes for misfire on these 5.4 3V engines are spark plugs and coils.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
and
A few other causes can be injector malfunction and intake air leaks.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
and
https://www.2carpros.com/articles/automotive-engine-misfire-code-p0300-causes-and-solutions
Hope this helps.
Cheers, Boris
Monday, March 25th, 2024 AT 5:35 AM
OREO101
  • 82 POSTS
Yes, it does!
Thanks!
Monday, March 25th, 2024 AT 11:36 AM
BORIS K
  • 765 POSTS
Thank you for using 2CarPros.
Please let us know if we can assist with anything else car related.
Cheers, Boris
Tuesday, March 26th, 2024 AT 6:52 AM
