Car will not start, sounds like jump time
CARLAJEAN
  • 2004 CHEVROLET CAVALIER
  • 2.2L
  • 4 CYL
  • MANUAL
  • 195,100 MILES
Car died while driving lost 2 quarts oil, sounds like it jumped time it just whines turning over, will not start and low compression ! Car did not use any at all. There is not any oil in water or water in oil ! HELP
Saturday, January 23rd, 2016 AT 10:18 AM
HMAC300
  • 48,600 POSTS
This may be two fold it may have blown a head gasket and jumped time. If compression is equal all across like 90 psi or less then it's probably a chain then get it tested for a head gasket as well.
Saturday, January 23rd, 2016 AT 11:07 AM
CARLAJEAN
If it is the head gasket would it leak oil
Saturday, January 23rd, 2016 AT 11:12 AM
HMAC300
  • 48,600 POSTS
It could either leak oil to the coolant, into the cylinder or outside the engine. At base of cylinder head and block mating surface. It should be checked however first.
Saturday, January 23rd, 2016 AT 11:45 AM
Related Engine Not Running Content
