Car tries to start but no dice
NEW2FORD619
  • 2000 FORD CONTOUR
  • 77,000 MILES
I try to start my contour but cannot get it to fully start, it tries. I can do the old gas rag in the intake trick to get it to start but then it goes dead on me again. Everything else is fine but I just can't get it to start and run.
Sunday, November 3rd, 2013 AT 10:51 PM
Try checking the fuel pressure and injection pulses-
Sunday, November 3rd, 2013 AT 11:17 PM
  • 108,427 POSTS
You have a fuel pressure issue or the injectors are not getting power. Check fuel pump pressure to start. If you need directions, see our homepage under the DIY section. Also, placing a gas soaked rag in the intake is very dangerous. If there is a backfire, the rag will most likely catch fire. Be careful!
Monday, November 4th, 2013 AT 4:43 AM
NEW2FORD619
I checked my fuse box and my R1 fuse is busted! So I check the manual and it says thats the one that goes to the fuel pump! Can I replace this? If so with what?
Monday, November 4th, 2013 AT 10:20 AM
NEW2FORD619
Okay so my fuel pump relay is busted and I wanna know where my fuel injector relay is, maybe replace both?
Monday, November 4th, 2013 AT 10:25 AM
  • 108,427 POSTS
Under the hood in the relay box.
Monday, November 4th, 2013 AT 7:42 PM
