Car missing
HEATHER ESTES
  • 1999 OLDSMOBILE INTRIGUE
  • 3.5L
  • V6
  • 143,945 MILES
I just bought this car two weeks ago and it has developed a miss in it. I am asking about this because it is unlike any other in a vehicle I have owned. If you give it gas from the bottom of the pedal it spits and sputters between 30 and 60 miles per hour but if you push from the top of the pedal it is generally pretty smooth only misses a couple of times. I'm really at a loss for what this could be.
Sunday, February 10th, 2019 AT 8:06 PM
  • 108,524 POSTS
The first thing you need to do is check the computer for diagnostic trouble codes. That will indicate which cylinders are misfiring and if there are any other problems we need to know about.
Here is a quick video which shows how to use a scanner:
https://youtu.be/YV3TRZwer8k
Now I realize most people don't own a scanner. If that is the case, most parts stores will scan it for free. Once you do that, let me know what codes are found.
Also, here is a link that discusses misfire conditions and how to check and repair many of them.
Sunday, February 10th, 2019 AT 8:47 PM
