Buzzer sounds shortly after starting
BAHARRIS
  • 1990 VOLKSWAGEN CABRIOLET
  • 4 CYL
  • 204,000 MILES
I have a buzzer that sounds shortly after starting car. No lights on dash light up. Have replace one oil pressure switch. What else could it be? Oil level is fine. Temperature gauge also not working.
Sunday, June 23rd, 2019 AT 7:43 AM
  • 108,554 POSTS
Welcome to 2CarPros.
When you say buzzer, do you mean the same noise as when a door is open? Is the top secure? Is the sound continuous? Can you record it and upload it for me to hear?
Sunday, June 23rd, 2019 AT 10:03 PM
BAHARRIS
It does not have a door sensor or roof sensor that I know of. Yes, it is continuous. When first started it is not there, then in about five minutes it starts. It is behind the instrument cluster somewhere. I will try to record it but I am not very tech savvy.
Monday, June 24th, 2019 AT 6:32 AM
  • 108,554 POSTS
The door should have an indicator that it's left open or at least the key is in the ignition. And no light is on? Try your best to record it. Most people just use their smart phones to record.
Monday, June 24th, 2019 AT 5:36 PM
