I am still getting no resistance on the brake when driving
MIKE KRAMER
  • 2003 VOLKSWAGEN JETTA
  • 2.0L
  • 4 CYL
  • MANUAL
  • 114,000 MILES
Hello. I wore my right rear driver side break pad down so far that the caliper snapped. I replaced both rear brake pads, both calipers on each side, refilled the brake fluid because it leaked all out during the break, but I am still getting no resistance on the brake when driving. I pump it several times and it feels like it is working and then straight to the floor it goes with no resistance and I can just barely stop.
Saturday, November 24th, 2018 AT 7:00 PM
  • 108,550 POSTS
Did you bleed the brake system after the repairs? Here is the procedure for doing it
Brake system, bleeding without pressure bleeder
- Build-up brake pressure in brake system by pumping brake pedal.
- Connect hose from bleeder bottle to brake bleeder valve at each wheel in turn (Bleeding sequence).
- Open bleeder valve.
- Hold brake pedal down, close bleed screw.
Note: The brake fluid level in the reservoir must not fall below the MIN mark during bleeding.
- Release brake pedal.
- Repeat operation until brake fluid flows without air bubbles.
Brake fluid, changing
Refer to Brake Fluid; Service and Repair.
Here is a link that shows how in general to bleed the system:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Here is a link that describes reasons a brake pedal goes to the floor.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Now, if you have done this and there is no air in the system, I suspect the master cylinder has failed.
Let me know if you bled the brakes as described above.
Friday, April 23rd, 2021 AT 12:35 PM
