Brake lights stay on
RONH12
  • 2010 MAZDA 3
  • 160,000 MILES
Hi I am having the weirdest problem with my brake lights. I replaced the brake sensor located under the pedal with a brand new one but had no luck. Even weirder is that when I pull the fuses out for the lights they stay on but when I remove the internal light fuse they start working normal. Any idea what might be the issue?
Sunday, April 3rd, 2016 AT 9:40 AM
HMAC300
  • 48,600 POSTS
Have it scanned for codes it may be a body control module problem.
Monday, April 4th, 2016 AT 7:21 AM
RONH12
Ok so I used my tester (Alcatel 708) and it does not have any error codes for bcm. I also discovered that the a/c does not engage.
Monday, April 4th, 2016 AT 5:34 PM
HMAC300
  • 48,600 POSTS
Your tester may not be able to test for a bcm problem, i'm not familiar with that scanner. For a/c check relay and fuse under hood.
Tuesday, April 5th, 2016 AT 6:23 AM
