Trunk not opening
JAMESBRAZENDALE
  • 2004 VOLKSWAGEN GOLF
  • 1.6L
  • MANUAL
  • 91,000 MILES
My boot recently started playing up and eventually would not open at all. When I started to try and diagnose it I noticed that when I opened the handle the rear wiper started moving. I found it was a common fault with these cars and the cables had split causing a short in the flexible part of the wiring where the boot enters the car. I have soldered all the wires back together and stopped the short to the wiper but the boot release still will not work and I am aware that there is no fuse for this, only one for the CCM? That would be my next check? I do have twelve volts getting to the release latch itself so I am not sure what else could be the problem?
Thanks
Wednesday, July 5th, 2017 AT 8:36 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,589 POSTS
Nine times out of ten it is the latch itself that goes bad. Here is a video that will give you an idea on how to change it.
https://youtu.be/Ho3AykfdzHA
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Friday, July 7th, 2017 AT 12:07 PM
