Block heater location
JOHNSON GRANDE
  • 1999 MAZDA PROTEGE
  • 1.6L
  • 150,000 MILES
Where is block heater if equipped and where can I put magnetic engine heater besides oil pan?
Thursday, December 15th, 2016 AT 11:59 AM
HMAC300
  • 48,600 POSTS
Oil pan may be aluminum most block heaters are put in place of freeze plugs. A magnetic one should go on block by water jacket which would be on side of cylinder.
Thursday, December 15th, 2016 AT 12:07 PM
STEVE W.
  • 13,167 POSTS
On the 1.6. If it has a factory block heater it should be in the freeze plug location above the oil filter. Magnetic heater would stick to the block if you can find a place that is flat enough.
If you wanted one that was not real hard to install you could opt for a heater hose mounted tank style or a lower radiator hose unit.
With them you can use a couple hose pinching clamps to block the water, cut the hose, install the heater unit, remove the clamps, route the power cord, and you are done.
Thursday, December 15th, 2016 AT 3:07 PM
